CAD tip # 12828:
applies to: Inventor · |
Tip 12508: | How to assign an expression (not value) to a user parameter with iLogic? |
Tip 12432: | Parse/replace Inventor iProperties using regular expressions. |
Tip 11801: | What is the difference between ThisDoc.Document and ThisApplication.ActiveDocument in iLogic? |
Tip 11542: | How to reset the top browser node name back to the file name? |
Tip 9561: | iLogic macro for exporting IDW/DWG Inventor drawings to DXF. |
Intersection osnap does not find the intersection.
Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs. « | » Do you know since when you are using Fusion 360?
