CAD tip # 7249:
applies to: AutoCAD · AutoCAD Architecture · |
Tip 13749: | How to add the SEARCH/REPLACE command into AutoCAD Web? |
Tip 13139: | How to insert a new line into multiline text in the Find/Replace command? |
Tip 12421: | Wrong units in an imported DXF file. |
Tip 9265: | RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...) |
Tip 7892: | How to find blocks with an empty (not-filled-in) attribute? |
Do you need to change resolution, mirroring or other parameter in the existing PLT file?
How to import CEL files (Microstation blocks) into AutoCAD? « | » How to load/install a LISP application in AutoCAD?
