CAD tip # 10028:
applies to: AutoCAD · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13858: | Is there also a SETBYBLOCK command? |
Tip 13450: | How to create a complex line type with text always upside down? |
Tip 13435: | Bulk setting of layer properties according to the object in that layer. |
Dimension with fixed length of extension lines (fixed dim.line offset) « | » Inherit properties in additional continue dimensions.
