CAD tip # 12040:
applies to: AutoCAD · |
Tip 13965: | Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic) |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13858: | Is there also a SETBYBLOCK command? |
Easter Egg in Architectural Desktop R3.
Random shape and appearance of an Inventor part or assembly. « | » Sel2BlkRef (blockify) - replace repeating objects with block references
Featuring: Save your floating licenses (NLS) consumed by inactive users - free unused licenses with LogOff 2006 |
