New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 3515:
Question
TFW, JGW, PGW, BPW, EWW, SDW, etc. are the georeference ('World') files for raster images in TIFF (.TIF), JPEG (.JPG), PNG (.PNG), BMP (.BMP), ECW (.ECW or SID (.SID) file formats.
Autodesk Map (or Raster Design or the GeoRefImg AutoCAD utility) can use these 'World' files directly to place the inserted raster images automatically.
A TFW/JGW file has the same filename as the main image file. It uses a textual (ASCII) format - e.g.:
1.50000000000000 (X scale, pixel size in meters) 0.00000000000000 (affinity - Y-scale in X dir.) 0.00000000000000 (affinity - X-scale in Y dir.) -1.50000000000000 (Y scale) 1934001.50000000000000 (X coordinate of the upper left pixel) 1187698.50000000000000 (Y coordinate of the upper left pixel)TFW file can be created also automatically - see the IWORLDOUT command in Autodesk Raster Design product or the latest versions of GeoRefImg.
MapCO
5.1.2004
97257×
applies to: AutoCAD Map 3D · Raster Design ·
