New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 7426:
Question
You are trying to use the command "Import AutoCAD block" (Annotate > Symbols) in your Inventor drawing environment and this function (icon) is grayed out?
The funtion of importing a specific external block from a different DWG file is active only in Inventor drawing views using the DWG format (not the IDW). Create a drawing based on the Standard.dwg template - then you will be able to import AutoCAD blocks.
Inventor2011
27.6.2010
10435×
applies to: Inventor 2011 ·
