CAD tip # 14088:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Plant 3D · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D · AutoCAD LT · |
Tip 14033: | Clipping blocks, images, curves, xrefs - everything, into any shape |
Tip 11608: | Trim to rectangle - cut out a part of a DWG drawing. |
Tip 11528: | Diagonal line across a table cell in AutoCAD. |
Tip 8846: | Parametric triangles - isosceles, right-angled, equilateral |
Tip 7585: | Plotting/exporting a series of drawing frames composed in a DWG drawing (or creating layouts). |
3D terrain model of any place in Czechia - elevation data by the Czech Land Survey Office (CUZK) into Civil 3D. « | » JavaScript API support in AutoCAD and AutoCAD LT.
