  Visitors: 4288
CAD tip CAD tip # 14093:
3D terrain model of any place in Czechia - elevation data by the Czech Land Survey Office (CUZK) into Civil 3D.
A - answer On the Civil3D.cz blog you will find a useful tip describing how to easily and free of charge obtain a 3D terrain model of any place of the Czech Republic.
The 3D point data in the form of XYZ coordinates can be obtained from the dataset "Altimetry - DMR 5G". The 5th generation digital elevation model of the Czech Republic is provided by the Czech Geodetic and Cadastral Office (ČUZK) and it is provided in the S-JTSK coordinates. These can be directly imported into the Autodesk Civil 3D software. The reported mean error in the elevation of these datapoints is 0.18 m in exposed terrain and 0.30 m in forested terrain.
The exact procedure and recommendations for generating the terrain surface can be found in the above blog or in the video demonstration of the procedure for generating terrain from CZ elevation points:
Civil3D
19.4.2024    1030×
Prices - CAD eShop:
applies to: Civil 3D 3D ·
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 12988:Where are Autodesk Infraworks building, road and terrain models loaded from?
Tip 11511:Assigning elevations to 2D contours (isolines).
Tip 11068:Unknown icon in an AutoCAD Civil 3D project.
Tip 10682:Automatic classification of drawing objects by their properties.
