New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip CAD tip # 9711:
Question
With the free utility CADstudio 3DConstruct you can convert any surface mesh object (3DMesh, 3DFaces) or a wireframe 3D model to a solid formed by a frame construction. The original 3D face edges are "wrapped" with solids defined by given profiles. The profile for the resulting construct can be a circle (cylinder), square (box) or any other closed curve. Optional 3D blocks can be inserted into construct node points. The construct is created in the layer 3DCONSTRUCT.
Download the 3DConstruct utility from Download, load it into AutoCAD with APPLOAD and start the command 3DCONSTRUCT. The source 3D mesh objects (e.g. from the utility 3DPlot) need to be exploded first to 3D faces (3DFace) with EXPLODE. You can also construct solids if you convert them first to mesh models. Possible wireframe models must be prepared to the layer 3DCONSTRUCT.
Examples of using 3DConstruct and the resulting 3D models are presented in the video:
You can use this tool to generate architectural models from math surfaces, for 3D printing, etc.
Sample models wrapped with 3DConstruct - in 3DConstruct.dwg in the Block library.
ACAD
26.2.2014    26834×
applies to: AutoCAD ·
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 11311:Importing STL files directly into AutoCAD - STLin.
Tip 11054:Difference volume (3D solid) between two TIN surfaces (sets of coordinates)
Tip 10682:Automatic classification of drawing objects by their properties.
Tip 9651:Convert a DWG 3D mesh model to an Inventor 3D solid part.
Back    All CAD Tips
Categ:
VRMLout More info
