New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 7809:
Question
When adding diameter dimensions, Inventor automatically adds the diameter symbol in front of the dimension value - by the setting in the Style editor:
If you want to add the diameter mark also to a standard dimension, or in cases when the automatic diameter marks are switched off, double-click on the dimension object and in the Edit dimension dialog use the button Insert symbol (on the right):
Inventor2011
*CAD
22.2.2011
26373×
applies to: Inventor 2011 ·
