CAD tip CAD tip # 8241:
Question
The individual web services of the "Autodesk Cloud" (Construction Cloud, ACC, resp. "Autodesk 360") can be used from your web browser, using a couple of URL addresses. Here is the list of them.
  • User account
    All cloud services require login with your unified "Autodesk ID" (either free from any Autodesk web service, or your subscription account). The Subscription Coordinator in your company may limit your access to cloud services that might be non-compliant with your company policy. To setup your Autodesk ID account and access your usage statistics of cloud service, go to accounts.autodesk.com
  • Cloud Documents
    The most popular Autodesk Cloud service - Documents - can be used on the web address 360.autodesk.com (or cloud.autodesk.com). The mobile DWF viewer Autodesk Design Review can be downloaded from the Apple App Store.
  • Cloud Rendering
    The cloud rendering service (former "Neon"), including download of the AutoCAD and Revit plufins, can be found on rendering.360.autodesk.com
  • AutoCAD 360
    The cloud version of AutoCAD - AutoCAD 360 (formerly "WS", including its mobile versions) - can be found on the well-known address www.autocad360.com resp. on the new web.autocad.com
  • Autodesk Forma (Shapemaker)
    Conceptual BIM design and project analysis using AI app.autodeskforma.com (or .eu)
  • Green Building Studio
    Energy analysis of BIM projects can be performed on the web site gbs.autodesk.com
  • ReCap Photo
    create textured 3D models from a series of photos recap.autodesk.com
  • ReCap 360
    share and collaborate on laser scan projects recap360.autodesk.com
  • Conceptual Energy Analysis
    This service is invoked directly from the Revit environment with the button "Analyze Mass Model".
  • Structural Analysis
    This service is invoked directly from the Revit environment with the button "Analyze in Cloud" - over the web structuralanalysis.360.autodesk.com.
  • Inventor Optimization
    This service is invoked directly from the Inventor environment with the Optimization add-on installed (see Download).
  • Autodesk FormIt
    The conceptual 3D BIM modeler app integrated with Revit and running as a Windows app or iPad app can be also launched in a web browser from app.formit.autodesk.com
  • Autodesk Buzzsaw
    The management of your AEC projects and documents, and publishing of the contents of Vault documents runs on the secured web site projectpoint.buzzsaw.com
  • Autodesk BIM 360 Docs
    BIM document management docs.b360.autodesk.com
  • Autodesk BIM 360 Glue
    cloud coordination of BIM projects bim360.autodesk.com
  • Autodesk Fusion 360
    cloud 3D CAD modeler for solid and surface models fusion360.autodesk.com resp. web.fusion.autodesk.com
  • Autodesk Configurator 360
    cloud product configurator - from Inventor models configurator360.autodesk.com
  • Autodesk Character Generator
    online generator of ready-to-animate 3D characters charactergenerator.autodesk.com
  • Autodesk PLM 360
    cloud-based PLM system compatible with Vault www.autodeskplm360.net
ACADRevitInvDWGBIM360Formacloud
29.9.2011   34180×   FAQ
this tip shared by ARKANCE experts applies to: ACAD · Revit · Inv · DWG · BIM360 · Forma · cloud ·
Tip 15155:How to collaborate on DWG files simultaneously (multiplayer mode, concurrent editing)?
Tip 15129:Failure to open a CAD file from OneDrive (AutoCAD, Revit, Inventor...)
Tip 15123:How can I combine a commercial and a personal (hobby) Autodesk Fusion license on a single PC?
Tip 15110:How to add special Thread types to Fusion - for 3D printing, DIN 477, E25, photo lenses...
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Back    All CAD Tips
Categ:
