New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 8361:
Question
By combining two freeware tools by Arkance Systems - VerticesBlk and InsertC/BlockC - you can easily annotate all vertices of a selected polyline with numbers and coordinates.
You will need an annotation block with one (or first) attribute for the future number (vertex ID) and optional other attributes - e.g. for coordinates XY, XYZ or just Z. An example of such block can be downloaded from the Catalog - see VertID:
Block VertID - download
Now import this block into your drawing (Insert) and load (Appload) the two LISP utilities VerticesBlk and InsertC (see Download).
First start the VerticesBlk command to insert the VertID block to all vertices of your polyline (LWPolyline, 3D Polyline etc.). Then start the BlockC command to renumber the labels with a series of incrementing numbers.
See the detailed procedure (Czech version) in the AutoCAD video #46
or on the CADstudioCZ channel on YouTube:
or see this animated GIF (click to enlarge):
ACAD
9.12.2011    27197×   FAQ
applies to: AutoCAD ·
Tip 10544:How to highlight polyline nodes and segments and directions?
Tip 7530:How to add blocks to line endpoints?
Tip 7099:Blocks perpendicular to a polyline.
Tip 5384:How to insert blocks at each polyline vertex (or just at endpoints)?
Back    All CAD Tips
Categ:
