CAD tip # 8365:
applies to: Inventor · |
Tip 13692: | What is the precision in Revit? |
Tip 13426: | Use of alternative units for arithmetic in dimensions (without square brackets). |
Tip 13228: | DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller). |
Tip 13013: | Converting a 3D mesh to a 3D solid in Fusion 360. |
Tip 12777: | Arithmetic and trigonometric functions available in Revit expressions. |
Green corners around drawing views in Inventor. « | » Automatic vertex labels with autonumbering and coordinates.
