  Visitors: 3669
CAD tip CAD tip # 12961:
Bolt-nut constraint/joint in Fusion 360.
A - answer For bolt connections, use the Cylindric type of constraint (joint, coupling) in combination with the linked Rotation joint in Fusion 360 to constrain the nut movement along the length of the bolt thread. Set the desired joint limits and angular speed of the nut rotation.
The detailed workflow and parameters of the ribbon Assemble are illustrated in a video tip from the Arkance Systems' YouTube channel:
Fusion360
25.5.2021    13022×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 12762:Multiline and vertical text in Fusion 360 sketches.
Tip 12458:How to align/center text and other objects in Fusion 360?
Tip 11522:How to create 3D splines in Fusion 360 - e.g. for pipe axes?
Tip 10769:What is the orange marker on the sketch icon in Fusion 360 model tree?
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
