New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 8048:
Question
Yes, 3D models from AutoCAD (DWG) can be directly imported into Revit - both solid models and surface (mesh) models.
ACADRevit
17.6.2011    6608×
Prices - CAD eShop:
applies to: AutoCAD · Revit ·
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Tip 14209:Optimized stacking od boxes into a container of a given size - 3D nesting.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Back    All CAD Tips
Categ:
