New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 6816:
Question
The DWG drawing sheets save from Inventor behave as noneditable blocks - how to edit them?
There are two ways for saving DWG files from Inventor.
When you just use DWG (instead of IDW) as the default format for your Inventor drawing sheets, Inventor saves its part objects as blocks (to keep the associativity). Such DWG files are not intended to be heavily edited in AutoCAD (the TrueConnect functionality).
If you want a copy (no more associative to the 3D model) of your Inventor drawing sheet to be edited in AutoCAD (or LT) as AutoCAD entities, use the "Save Copy As" command (I > Save as > Save copy as) in your drawing sheet and save your sheet as "AutoCAD Drawing (DWG)". Such DWG files use layer and style mappings to display plain AutoCAD entities the same way as in Inventor.
Inventor2010Inventor2009Inventor2008ACADACLT
23.7.2009    24613×
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Tip 14367:What CAD formats are supported in the free Personal (hobby) license of Autodesk Fusion?
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14335:Convert TrueType text in an Inventor sketch to a contour curve.
Back    All CAD Tips
Categ:
LogOff 2006 More info
