CAD tip CAD tip # 6815:
Question
This error message is caused by an attempt to create block of the same name as the block already contained (nested) in the block you insert.
For example, if you have an empty drawing, you create a new block "ABCD" in it and then you save the whole drawing to a file ABCD.DWG, any attempt to insert this DWG (as a block) to another drawing will invoke this error message. The proper procedure for this was to save your block to a DWG file with WBLOCK.
This nam collision may also appear on deeper nesting levels (a block in a block in a block).
ACADACLT
23.7.2009   16178×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15129:Failure to open a CAD file from OneDrive (AutoCAD, Revit, Inventor...)
Tip 14941:Fusion: The code execution cannot proceed because Qt6Widgets.dll or acge230.dll was not found.
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14260:How to extract attributes with tag names containing accents?
Tip 13180:FDO connection to a WMS service fails with "Connection failed"
Back    All CAD Tips
Categ:
