CAD tip CAD tip # 10596:
Question
If you want to add more color schemes to Inventor, or change any color hue of an element in existing color scheme, you can use the Inventor Color Scheme Editor.
This application can be found in additional Inventor user tools, a kind of Inventor "Express Tools". These tools need to be installed first. You can do so by running the setup program:
C:\Users\Public\Documents\Autodesk\Inventor 20XX\SDK\usertools.msi
with adequate user rights (best as the Administrator).
Then you can launch the editor application InventorColorSchemeEditor.exe from the folder:
C:\Users\Public\Documents\Autodesk\Inventor 20XX\SDK\UserTools\ColorSchemeEditor\Bin\
In the "Inventor Color Scheme Editor" application dialog then choose the requested Inventor version (RegistryVersion) and in the selected color scheme edit the hue (change color by clicking on the color panel) and transparency of a given user interface (UI) components - e.g. the axes triad, background, manipulators, object selection highlighting, sketch elements, glyphs, etc.
Do not forget to Save your changes. The settings are stored in the Registry.
Inventor
20.11.2015   26073×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 14274:How to unify part thumbnails in Inventor BOMs? (white background)
Tip 13920:Saving your Inventor model in the presentation color scheme, thumbnails with a white background (iLogic).
Tip 12326:How to customize your Fusion 360 background color? (any color theme)
Tip 12242:How to increase contrast between a constrained and underconstrained curve in an Inventor sketch?
Tip 12152:Sketch lines linewidth - how to make Inventor lines thicker for a 4K display?
Back    All CAD Tips
Categ:
