CAD tip CAD tip # 8293:
Question
The new function for drawing dynamic arrays in AutoCAD 2012 allows to specify the array parameters dynamically, by mouse dragging. You can subsequently edit your array using parameters entered in the context ribbon for arrays.
If you prefer to use the parameters right from the beginning, when drawing the array, use CUI to add the following menu macros to your ribbon or toolbars (successively for rectangular, polar and path arrays):
^C^C_select;\_arrayrect;_p;;;1;1;;_x;(sssetfirst nil (ssadd(entlast)))(princ)
^C^C_select;\_arraypolar;_p;;\;;_x;(sssetfirst nil (ssadd(entlast)))(princ)
^C^C_select;\_arraypath;_p;;\1;_d;_x;(sssetfirst nil (ssadd(entlast)))(princ)
Since version 2012 SP1 you can also use the old way of creating arrays with the ARRAYCLASSIC commans.
(original concept by Silvia Menon)
ACAD2012
29.10.2011   18172×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 ·
Tip 14746:Connecting nearby points in a point field by lines.
Tip 14665:Display complex linetypes on 3D curves in plain AutoCAD.
Tip 13858:Is there also a SETBYBLOCK command?
Tip 13666:Oblique rectangular array in AutoCAD.
Tip 13452:HideItem - hiding individual items in AutoCAD arrays or attributes
Back    All CAD Tips
Categ:
