CAD tip CAD tip # 8729:
Question
If you need to compare two DWG files a find their differences - changed, erased and added geometry - you can use the free application Autodesk Design Review (see DL Download).
This tool employs the DWF/DWFx drawing format and its function "Compare Sheets" allows to highlight in color all differences in the geometry of both drawings.
The workflow of generating DWF from a drawing and comparing two schemes from AutoCAD P&ID is described in a video available in the CAD Video section - see AutoCAD video #12
P&ID-compare
or on the ARKANCE's YouTube channel:
ACADACLTPIantDWGDWF
31.7.2012   37516×   FAQ
this tip shared by ARKANCE experts applies to: ACAD · ACLT · PIant · DWG · DWF ·
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14285:How to identify duplicate blocks in AutoCAD DWG drawings? SelDupBlk.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Back    All CAD Tips
Categ:
