New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 10031:
Question
If you want to create dimensions with fixed (constant) length of extension lines (counted from the dimension line), use the dimensioning variables DIMFXL and DIMFXLON.
You can also set this offset in the dimstyle dialog in "Fixed length extension lines":
Even an extremely high value for the extension line length never extends the extension line "inside" the dimensioned object (always stays outside).
If you want to create dimensions with fixed offset (distance) of the dimension line from the dimensioned object (basepoints), enter - on the "Specify dimension line position:" prompt - the coordinate/position of the dimension line as:
123.4<90
(distance/offset 123.4 units, direction 90°)
You can preset such entry to a menu macro.
ACADLT
3.10.2014    19478×
applies to: AutoCAD · AutoCAD LT ·
Tip 14271:How to use the STRETCH command to resize an object to a specific size?
Tip 14059:Import coordinates from CSV files into Fusion profiles.
Tip 14045:In my AutoCAD script file (.SCR) I cannot enter a name containing a space.
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 13495:How to create a full diameter dimension with two arrows?
Back    All CAD Tips
Categ:
VRMLout More info
