New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9860:
Question
With the mobile version of AutoCAD - AutoCAD 360 you can use your smartphone or tablet to display your current GPS position in a DWG drawing of a city map, construction or utility site. And the DWG contents can be automatically synchronized with your "desktop" version of AutoCAD or AutoCAD LT.
If you have the particular drawing (map) geolocated in a coordinate system in AutoCAD, the GPS coordinates (WGS84) will match automatically, otherwise you can se the location and possible rotation of the drawing also in AutoCAD 360 - see the command (the bottom menu) Location > Settings:
Switch on the GPS service on your phone/tablet and enable the location display with Location > My location. Your current location ("where am I") will be displayed in the DWG drawing with a blue point (an example - city map of C.Budejovice, Samsung Galaxy S4).
AutoCAD 360 is a free app for Android and iOS (iPhone, iPad) - see Download.
ACAD360ACADWSMapCivil
5.6.2014    35419×
applies to: AutoCAD 360 · ACADWS · AutoCAD Map 3D · Civil 3D ·
Tip 14457:What is the difference between the commands GEOGRAPHICLOCATION, MAPCSASSIGN and GEOCSASSIGN in Map/Civil 3D?
Tip 14414:Link geo-tagged photos from your mobile phone to AutoCAD DWG maps.
Tip 12914:Geo2GPS - GPS or UTM coordinates or web map from any coordinate of an AutoCAD DWG (Google Street View).
Tip 11970:How to find the map coordinate system of a drawing?
Tip 10848:GeoCode with what3words location codes.
Back    All CAD Tips
Categ:
