  Visitors: 2629
CAD tip CAD tip # 9862:
How to import a DGN 3D model into Autodesk Inventor?
A - answer You can import a 3D model from a DGN file into Autodesk Inventor with standard AutoCAD and Inventor tools without any add-on third-party utility. You just need to choose proper settings of AutoCAD variables so that your 3D geometry will be properly translated.
The following video illustrates the procedure of converting a DGN model previously imported (opened) in AutoCAD to a geometry supported in Autodesk Inventor.
Inventor
9.6.2014    15423×
Prices - CAD eShop:
applies to: Inventor ·
Tip 9180:CAD file formats supported in Autodesk Navisworks 2014.
Tip 8703:File formats compatible with Autodesk BIM 360 Glue.
Tip 8549:CAD file formats supported in Autodesk Navisworks 2013.
Tip 8104:File formats supported in Autodesk Navisworks 2012.
Tip 5401:Which CAD formats can be imported into Revit?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
