New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 7398:
Question
You certainly know and frequently use the LAYER command in AutoCAD. The more advanced users probably know also its variants -LAYER and CLASSICLAYER.
But the undocumented command +LAYER is one of the least known AutoCAD commands. And it can be quite useful in some situations. This line command allows to easily switch layer filters (displayed layers) in the palette "Layer Properties Manager". So you can use a command (from a macro, from menu, etc.) to switch on one of the existing layer group filters, properties filters, unreconciled layers, layers with viewport overrides, or display all layers in the layer palette. The command prompts change dynamically - they follow the currently defined layer filters.
_+LAYER
This command is not available in AutoCAD LT.
ACAD2011ACAD2010ACAD2009
8.6.2010    33891×
applies to: AutoCAD 2011 · AutoCAD 2010 · AutoCAD 2009 ·
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Tip 14304:How to generate a report of used blocks including their visibility status in AutoCAD LT?
Tip 14285:How to identify duplicate blocks in AutoCAD DWG drawings? SelDupBlk.
Tip 14242:How to find the minimum, maximum or local extreme of a 2D or 3D curve?
Tip 14230:How to transfer layer properties from another DWG drawing?
Back    All CAD Tips
Categ:
