CAD tip CAD tip # 7396:
Question
AutoCAD Map 3D and AutoCAD Civil 3D support effective storage of non-graphical entity data as "object data" (OD). How can you convert existing block attribute information to this object data?
1. First method:
In the object data definition (ADEDEFDATA, Map > Define object data) choose "Create new table" to create a blank table containing identical items as the existing block attributes (tags). No default values are neccessary. Then start the ADEGENLINK command (Generate links, Map > Database) and set its dialog similarly to the picture. Select the appropriate linkage type (Blocks), under "Data Links" select "Create Object Data Records", choose your defined table, choose block, select OK. The links are generated automatically and the attribute values are copied into object data (OD).
Map OD - ADEGENLINK
2. Second method:
If you want to "cheat" and you don't want to define tables, just export (MAPEXPORT) the blocks to an ESRI shapefile (SHP) while using the OD option, erase the blocks and then re-import the shapefile into AutoCAD Map (MAPIMPORT) - when the import dialogue shows up, choose to import data in the OD tables under the Data column (see the "..." button) and set point mapping to blocks (the last column). This will automatically create tables and the desired fields, you just have to play around with modify the tables.
Map OD - export SHP
Map OD - import
MapCivil
7.6.2010   34305×
this tip shared by ARKANCE experts applies to: Map · Civil ·
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 15063:How do I convert the geometry of a Civil pipe network to 2D, or to SHP format?
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Tip 14935:"Mechanical" osnap modes in AutoCAD Mechanical.
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Back    All CAD Tips
Categ:
