CAD tip # 12118:
applies to: Revit · |
Tip 13985: | Advanced pressure drop calculations in Revit (multiple connections). |
Tip 12671: | Import Excel table by snapping a photo of it. |
Tip 12184: | Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD). |
Tip 11705: | Split and join multi-column schedules on Revit drawing sheets. |
Double-click to edit raster images in DWG drawings. « | » The Ctrl+Shift+letter hotkeys do not work (e.g. Ctrl+Shift+C in AutoCAD)
