New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11398:
Question
You can also edit block attributes when editing a DWG drawing on your mobile phone or tablet (e.g. Android, iOS).
You will need the "Pro" version of AutoCAD mobile app (AutoCAD 360) to edit attributes (it comes with your standard AutoCAD or LT license). The editing can be performed in the properties palette.
Tap Modify in the bottom bar and select the requested block reference in your drawing. Open the palette using the top right arrow button.
Open the tab "Properties: Block Reference" in the palette. In the Attributes section you can choose the requested attribute or easily (easier than in full AutoCAD) add a new one with the "+" button. Choose Edit (or Delete) by tapping on the local menu icon "|". Edit the attribute value to a new one and save your setting with OK.
Attributes edited, added or deleted in the off-line mode will be automatically updated in in the next online synchonization.
ACAD360Mobile
21.4.2017    14677×
applies to: AutoCAD 360 · Mobile ·
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14395:CheckAngles - checking the allowed line angles in the DWG drawing (e.g. only ortho)
Tip 14367:What CAD formats are supported in the free Personal (hobby) license of Autodesk Fusion?
Tip 14215:IF statement in AutoCAD text fields and attributes.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
