  Visitors: 4469
CAD tip CAD tip # 8077:
Firefox doesn't display 3D DWF data in the QuickShare viewer.
A - answer Online DWF viewer Autodesk Design Review QuickShare (now included in Autodesk 360 cloud services) works only in the newest versions of web browsers supporting HTML5 and WebGL.
The Firefox browser supports these standards since version 4.0 (better in 5.x). Make sure you have the current version of Firefox. Plus your graphics card (its driver) must support WebGL and first of all the WebGL support must be enabled in Firefox.
This setting can be done on the Firefox configuration page: in the address line type about:config and scroll down in the parameter list (listed alphabetically). Verify or change (by double-clicking) the settings of the parameter webgl.disabled - should be se to false (OK in most cases), and set the parameter webgl.force-enabled to true (this is the source of 3D problems in most cases).
You don't need to save anything, just switch back to the page with CAD data and refresh it (F5). Now the 3D mode should work.
You can verify your settings on the bicycle 3D model:
DWF
14.7.2011    12081×
Prices - CAD eShop:
applies to: DWF/Design Review ·
Tip 13026:How to switch Vault to the Forge-based CAD viewer "Autodesk Viewer"?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 10517:How to enable/disable automatic display of PDFs published from Inventor?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10258:Digital signature of CAD files in the DWFx format.
