CAD tip CAD tip # 12325:
Question
Standard DWG viewers (e.g. DWG TrueView or cloud-based Autodesk Viewer) do not support special "steel" objects from Autodesk Advance Steel - they display them as lines or points only. So how to fully display DWG drawings from this software application?
There are basically two options:
  1. Get rid of the special objects - while still inside Advance Steel, either explode those objects to standard DWG entities, or export your DWG drawing to a neutral format - e.g. to 3D DWF, IFC or ACIS. These formats can be then viewed e.g. with Autodesk Viewer. To select the special Advance Steel objects, use the command QSELECT and select the object types starting with "AST".
  2. Install the "Object Enabler" for Advance Steel to your viewer - e.g. to the free Autodesk DWG TrueView or AutoCAD LT. This enabler "learns" the viewer to process also the special AST objects. Both the DWG TrueView and the necessary Object Enablers of the given version can be downloaded from DL Download.
    Note: on a computer with Advance Steel installed you don't need to install the Enabler.
    Note: if the objects stop displaying, try a repair installation of your Enabler (Windows Control Panels)
SteelDWGACLT
30.7.2019   39129×
this tip shared by ARKANCE experts applies to: Steel · DWG · ACLT ·
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Tip 14454:How to hide dimensions with zero- or small length?
Tip 6922:Product codes (registry) of Autodesk CAD applications.
Tip 6312:Making transfer of AutoCAD DWG files faster over WAN.
Back    All CAD Tips
Categ:
