Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8306:
Question
I am a crafter/hobbyist ("maker") - where can I find a good 3D CAD software which is inexpensive or even free?
For your maker activities, you can download and use e.g. the free 3D CAD modeler and fabrication tools based on Autodesk Inventor Fusion - Autodesk 123D Design and 123D Make.
"123D" is a family of free 3D solid modeling and fabrication software tools based on the same Autodesk technology used by millions of designers and engineers worldwide. Autodesk 123D is easy to use - you can design precise and makeable objects using smart tools that let you start with simple shapes and then edit them into more complex shapes. The Windows, Mac and cloud/mobile applications "123D" support many standard file formats.
You can also combine "123D Design" with "123D Catch" (Photofly/Photo Scene Editor) to make a 3D model of a real-world object from a series of photos.
For 2D CAD work you can use another Autodesk simple and free tool - the cloud version of AutoCAD - AutoCAD 360 (WS).
You can also use a free version (for makers) of the advanced 3D CAD/CAM/CAE tool - Autodesk Fusion 360.
DWGInvACAD
7.11.2011    26285×   FAQ
applies to: DWG · Inventor · AutoCAD ·
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Tip 14423:CAD data conversion in Alias ends on timeout.
Tip 14382:Steel and other materials according to DIN or EU standards for Fusion.
Tip 14367:What CAD formats are supported in the free Personal (hobby) license of Autodesk Fusion?
Back    All CAD Tips
Categ:
VRMLout More info
