CAD tip # 11505:
applies to: Revit · |
Tip 13891: | How to remove personal data from a document (Properties)? |
Tip 13800: | Visually compare 3D geometry in CAD and BIM files. |
Tip 13404: | How to import an IFC file in AutoCAD? |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
AutoCAD problem in Windows 10 Anniversary update (F8 key) « | » How to detect DWG files created as an export from Autodesk Revit?
