CAD tip CAD tip # 8636:
Question
One of the new functions in the web tool Autodesk Map Server version 2013 is the performance analysis report. You can use it to identify bottlenecks in generation and publishing of the contents of the individual map layers from various data sources.
A sample of such analysis shows that the longest part of the particular query (328.75 ms from the total 830 ms) was spent on generating the layer "Plochy povrch 0" of the class ZM_PLOCHA_POLY_0 and that this map probably contains only minimum of labels:
Performance Report
The "Performance Report" can be invoked from the Site Administrator console under the URL address http://SERVER/mapserver2013/mapadmin/performanceReport.php.
TB2013Map2013
16.5.2012   12447×
this tip shared by ARKANCE experts applies to: Topobase/MapServer 2013 · AutoCAD Map 3D 2013 ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14969:Examples of AI prompts and the challenges of using the Autodesk Assistant AI feature for analyzing and generating CAD geometry in AutoCAD and Fusion.
Tip 14804:Why do I see a lock icon on some tool palettes?
Tip 14281:Mapped network drives (S:, T:, X:, etc.) are not available in my CAD application.
Tip 13180:FDO connection to a WMS service fails with "Connection failed"
Back    All CAD Tips
Categ:
