New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 8632:
Question
With a simple iLogic macro you can check material assignment for each part saved from Inventor.
Creat a a new iLogic rule with the following contents:
materialName = ThisDoc.Document.ComponentDefinition.Material.Name If materialName = "Generic" Then objSPVoice = CreateObject("SAPI.SpVoice") objSPVoice.speak ("Your component has no material assigned") End If
As a trigger for this rule, set e.g. "Before document save". A part with no material assigned will report itself automatically on save, by "telling it" (voice).
The default material for parts, or iLogic macros can be preset in the part template - see I > Save as > Save copy as template.
Inventor2013Inventor2012
16.5.2012
14605×
applies to: Inventor 2013 · Inventor 2012 ·
