Autodesk Fusion 360 creates a separate version of your design history in the cloud (in your Hub) every time you save a design. If you need to go back to a previous version during the course of your work, use the Autodesk cloud service (the A360 hub).
In the Data Panel on the left (if not shown, click the icon with squares), locate your model and click the History tab. Select (e.g. by date, authoror appearance) the desired version and select Open from its menu (three dots on the right).
An alternative option is to click "View details in web" (in the older version, the "i" icon and then the "Open details in A360" link in the box that appears). This will open your Autodesk360 cloud hub (web browser window) with the model information. From there, select the desired version from the version drop-down list at the top. Then click on the button "Open in desktop application".
See the video demonstration on the Arkance Systems YouTube channel:
Of course, you can also start the entire version selection process directly from the A360 website (myhub.autodesk360.com or your team hub) in your web browser.
Featuring: Extend your AutoCAD LT productivity with our popular add-on CADstudio LT Extension
