  Visitors: 6224
CAD tip CAD tip # 13773:
What is the maximum paper size when plotting from AutoCAD?
A - answer The maximum user sheet size when plotting with the PLOT command varies depending on the driver (printer) used.
For example, for the "AutoCAD PDF" (or "DWG To PDF.pc3") printer, the maximum user-defined custom page size can be set to 5.08 m (5080 mm, 200x200 inches) in AutoCAD 2024. However, the largest page size in the PDF definition itself (v7) is up to 381 km.
5m longplot
For the printer (driver) "DWF6 ePlot.pc3", the largest user "paper" sheet size can be set up to 10 km (10,000,000 mm).
ACADADTPlantACADMCivilMapACLT
1.7.2023    42449×
Tip 13409:How to create Revit Window and Door schedules with legend views?
Tip 13056:How to copy DWG Properties from one drawing to another?
Tip 9855:Overview of postprocessors available in the CAM software Inventor HSM and Fusion 360.
Tip 9147:Batch publishing to PDF uses different margins than single prints.
Tip 7954:AutoCAD 2012: Generate 2D drawing views from 3D models.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
