CAD tip # 7959:
applies to: AutoCAD · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13858: | Is there also a SETBYBLOCK command? |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13822: | Fast layer visibility toggle ON/OFF. |
Lost dynamic properties (grips) of dynamic blocks.
Direct editing of any 3D model in AutoCAD or Inventor. « | » AutoCAD 2012: Generate 2D drawing views from 3D models.
Featuring: Save your floating licenses (NLS) consumed by inactive users - free unused licenses with LogOff 2006 |
