CAD tip CAD tip # 7954:
Question
The VIEWBASE command in AutoCAD 2012 (2013,2014...) can conveniently generate 2D views (projections) of any 3D solid. This command can be run in a layout.
If the model space of the current drawing contains a 3D object, the 2D views are generated from this 3D model. If there is no 3D object in the given DWG file, the command offers view generation from external Inventor 3D models (.IPT and .IAM files). But the 3D model inside the DWG drawing can be also imported from SolidWorks, Rhino, CATIA, Pro/ENGINEER, ACIS, Parasolid, IGES, STEP, JT etc. - so you can create the drawing views also from these sources of 3D CAD models (formats).
These documentation commands create projections in the selected directions - orthographic or isometric, you can specify the display style (shaded, hidden lines, tangencial lines...). When the model is updated, the user is prompted to update the drawing views. All created view representaions can be associatively dimensioned. The resulting drawing sheet can be exported to a separate DWG file (EXPORTLAYOUT).
An example of making views from an Ainventor model can be seen in the CAD video #31:
Video
ACAD2014ACAD2012ACADM2012
4.5.2011   34144×
this tip shared by ARKANCE experts applies to: AutoCAD 2014 · AutoCAD 2012 · AutoCAD Mechanical 2012 ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15065:AI rendering in Autodesk Forma Board.
Tip 15063:How do I convert the geometry of a Civil pipe network to 2D, or to SHP format?
Tip 15049:Inventor displays incorrect dimension lengths in my drawing views.
Tip 15034:How to integrate the PDF markup process in Bluebeam with Revit?
Back    All CAD Tips
Categ:
