Over 1.091.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9852:
Question
A standard import of 3D solids from DWG and other CAD formats does not allow exploding and editation in Revit projects.
Using the import in the in-place component mode can help to bring in such 3D models and edit them in Revit. By adding reference planes and parameters you can convert the imported 3D model to a standard Revit parametric 3D family (.RFA file).
See the video illustrating the conversion process from an AutoCAD 3D model (retaining wall) from a DWG block to a RFA family:
RevitDWG
2.6.2014    48241×
applies to: Revit · DWG ·
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13692:What is the precision in Revit?
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
