New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 6774:
Question
You can process and export your DWG drawing for plain AutoCAD using the export functionality in Architecture. But you can also perform conversion of the 3D model (or the individual objects) with the AecConvertTo3DSolids command. This function is also available in the Tools catalog.
ADT2010ADT2009ADT2008ABS
30.6.2009
29256×
applies to: AutoCAD Architecture 2010 · AutoCAD Architecture 2009 · AutoCAD Architecture 2008 · AutoCAD/Revit MEP ·
