CAD tip # 11561:
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Tip 13587: | Dynamic label of 3D coordinates. |
Tip 13006: | Calculated property descriptions (tobogan slide from floor to floor) |
Tip 12685: | ReLinkField - re-link fields to source objects. |
Convert entities or entity colors to separate layers.
Avoid name collisions between AutoCAD font- and symbol files (SHX). « | » How to set K-Factor and other parameters for sheetmetal unfolding in Fusion 360?
