CAD tip CAD tip # 7336:
Question
If you want to suppress the dynamic switching of contextual tabs in AutoCAD ribbons, you can use the setting in the Options dialog.
The button "Contextual Tab States" is available on the "Selection" tab in the OPTIONS command.
Context tabs (CZ version)
You can also disable context tab switching with the variable RIBBONCONTEXTSELECT (=0). Other parameters of the context ribbons are controlled by the variables RIBBONSELECTMODE and RIBBONCONTEXTSELLIM.
This option is not available since AutoCAD 2015 - its ribbons are always contextual.
ACAD2014ACAD2011ACAD2010ACLTADTCivilACADM
28.4.2010    30791×
this tip shared by ARKANCE experts applies to: AutoCAD 2014 · AutoCAD 2011 · AutoCAD 2010 · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
Tip 14643:Easy insertion of arrows into MText content.
Tip 14405:How do I create a 3D helix or 2D spiral sketch in Fusion?
Tip 14226:Cannot select multiple objects with Shift, ribbon tab "Multiple" is displayed.
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 13620:How to quickly rotate the view by 90° in AutoCAD LT?
Back    All CAD Tips
Categ:
Take advantage of orthophotos, point clouds, and design files. Get better quality design changes faster with Pointscene More info
