New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 7334:
Question
If you need to quickly select touching objects, you can use one of the useful Express Tools - FS (FastSel).
Depending on the setting of its work mode (FSMODE, "chain mode"), when you select a single object, all objects directly touching the selected object will be also selected (FSMODE=OFF), or even also the objects touching the touched objects will be selected (FSMODE=ON, chain selection).
Select with FS (FSMODE=OFF)
Select with FS (FSMODE=ON)
ACADADTCivil
*CAD
28.4.2010
14506×
