Autodesk products use product codes (ProductID, feature code), which identify (e.g. in the Registry) the type (flavor) of the CAD software product, its version and language localization (LocaleID).
The ProductID code has the following structure of the key:
ACAD-< ProductID >:< LocaleID >
Example: ACAD-8005:409 = AutoCAD Mechanical 2010 English
You can find these codes in the Registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD
The table of common ProductIDs:
2022 Product ID |
5100 | Civil 3D 2022 |
5101 | AutoCAD 2022 |
5102 | AutoCAD Map 3D 2022 |
5104 | AutoCAD Architecture 2022 |
5105 | AutoCAD Mechanical 2022 |
5106 | AutoCAD MEP 2022 |
5107 | AutoCAD Electrical 2022 |
5109 | AutoCAD LT 2022 |
5117 | AutoCAD Plant 3D 2022 |
5126 | Advance Steel 2022 |
2021 Product ID |
4100 | Civil 3D 2021 |
4101 | AutoCAD 2021 |
4102 | AutoCAD Map 3D 2021 |
4104 | AutoCAD Architecture 2021 |
4105 | AutoCAD Mechanical 2021 |
4107 | AutoCAD Electrical 2021 |
4109 | AutoCAD LT 2021 |
4117 | AutoCAD Plant 3D 2021 |
4126 | Advance Steel 2021 |
2020 Product ID |
3000 | Civil 3D 2020 |
3001 | AutoCAD 2020 |
3002 | AutoCAD Map 3D 2020 |
3004 | AutoCAD Architecture 2020 |
3005 | AutoCAD Mechanical 2020 |
3007 | AutoCAD Electrical 2020 |
3009 | AutoCAD LT 2020 |
3017 | AutoCAD Plant 3D 2020 |
3026 | Advance Steel 2020 |
2019 Product ID |
2000 | Civil 3D 2019 |
2001 | AutoCAD 2019 |
2002 | AutoCAD Map 3D 2019 |
2004 | AutoCAD Architecture 2019 |
2005 | AutoCAD Mechanical 2019 |
2007 | AutoCAD Electrical 2019 |
2009 | AutoCAD LT 2019 |
2017 | AutoCAD Plant 3D 2019 |
2026 | Advance Steel 2019 |
2018 Product ID |
1000 | AutoCAD Civil 3D 2018 |
1001 | AutoCAD 2018 |
1002 | AutoCAD Map 3D 2018 |
1004 | AutoCAD Architecture 2018 |
1005 | AutoCAD Mechanical 2018 |
1007 | AutoCAD Electrical 2018 |
1009 | AutoCAD LT 2018 |
1017 | AutoCAD Plant 3D 2018 |
2017 Product ID |
0000 | AutoCAD Civil 3D 2017 |
0001 | AutoCAD 2017 |
0002 | AutoCAD Map 3D 2017 |
0004 | AutoCAD Architecture 2017 |
0005 | AutoCAD Mechanical 2017 |
0007 | AutoCAD Electrical 2017 |
0009 | AutoCAD LT 2017 |
0017 | AutoCAD Plant 3D 2017 |
2016 Product ID |
F000 | AutoCAD Civil 3D 2016 |
F001 | AutoCAD 2016 |
F002 | AutoCAD Map 3D 2016 |
F004 | AutoCAD Architecture 2016 |
F005 | AutoCAD Mechanical 2016 |
F007 | AutoCAD Electrical 2016 |
F009 | AutoCAD LT 2016 |
F017 | AutoCAD Plant 3D 2016 |
2015 Product ID |
E000 | AutoCAD Civil 3D 2015 |
E001 | AutoCAD 2015 |
E002 | AutoCAD Map 3D 2015 |
E004 | AutoCAD Architecture 2015 |
E005 | AutoCAD Mechanical 2015 |
E006 | AutoCAD MEP 2015 |
E007 | AutoCAD Electrical 2015 |
E009 | AutoCAD LT 2015 |
E016 | AutoCAD P&ID 2015 |
E017 | AutoCAD Plant 3D 2015 |
2014 Product ID |
D000 | AutoCAD Civil 3D 2014 |
D001 | AutoCAD 2014 |
D002 | AutoCAD Map 3D 2014 |
D004 | AutoCAD Architecture 2014 |
D005 | AutoCAD Mechanical 2014 |
D006 | AutoCAD MEP 2014 |
D007 | AutoCAD Electrical 2014 |
D009 | AutoCAD LT 2014 |
D016 | AutoCAD P&ID 2014 |
D017 | AutoCAD Plant 3D 2014 |
2013 Product ID |
B000 | AutoCAD Civil 3D 2013 |
B001 | AutoCAD 2013 |
B002 | AutoCAD Map 3D 2013 |
B004 | AutoCAD Architecture 2013 |
B005 | AutoCAD Mechanical 2013 |
B006 | AutoCAD MEP 2013 |
B007 | AutoCAD Electrical 2013 |
B009 | AutoCAD LT 2013 |
B016 | AutoCAD P&ID 2013 |
B017 | AutoCAD Plant 3D 2013 |
2012 Product ID |
A000 | AutoCAD Civil 3D 2012 |
A001 | AutoCAD 2012 |
A002 | AutoCAD Map 3D 2012 |
A004 | AutoCAD Architecture 2012 |
A005 | AutoCAD Mechanical 2012 |
A006 | AutoCAD MEP 2012 |
A007 | AutoCAD Electrical 2012 |
A009 | AutoCAD LT 2012 |
A016 | AutoCAD P&ID 2012 |
A017 | AutoCAD Plant 3D 2012 |
A023 | Map Enterprise Client 2012 |
2011 Product ID |
9000 | AutoCAD Civil 3D 2011 |
9001 | AutoCAD 2011 (Registry Cookies: ACAD-9001; ARD-9001) |
9002 | AutoCAD Map 3D 2011 |
9004 | AutoCAD Architecture 2011 |
9005 | AutoCAD Mechanical 2011 |
9006 | AutoCAD MEP 2011 |
9007 | AutoCAD Electrical 2011 |
9009 | AutoCAD LT 2011 |
9016 | AutoCAD P&ID 2011 |
9017 | AutoCAD Plant 3D 2011 |
9023 | Autodesk Topobase Client 2011 |
2010 Product ID |
8000 | AutoCAD Civil 3D 2010 |
8001 | AutoCAD 2010 (Registry Cookies: ACAD-8001; ARD-8001) |
8002 | AutoCAD Map 3D 2010 |
8004 | AutoCAD Architecture 2010 |
8005 | AutoCAD Mechanical 2010 |
8006 | AutoCAD MEP 2010 |
8007 | AutoCAD Electrical 2010 |
8009 | AutoCAD LT 2010 |
8016 | AutoCAD P&ID 2010 |
8017 | AutoCAD Plant 3D 2010 |
8023 | Autodesk Topobase Client 2010 |
8028 | DWG TrueView 2010 |
8030 | AutoCAD Structural Detailing 2010 |
2009 Product ID |
7000 | AutoCAD Civil 3D |
7001 | AutoCAD (Registry Cookies: ACAD-7001; ARD-7001) |
700A | AutoCAD OEM (Registry Cookie: AOEM-7001) |
7002 | Map |
7003 | Inventor Series |
7004 | AutoCAD Architecture (former Architectural Desktop) |
7005 | AutoCAD Mechanical |
7006 | AutoCAD MEP (former Building Systems) |
7007 | AutoCAD Electrical |
7008 | Land Desktop |
7009 | AutoCAD LT (Registry Cookie: ACLT-7001) |
7012 | ADT for Raster Design |
7013 | Inventor Professional |
7014 | Inventor Professional for Routed Systems |
7015 | Inventor Professional for Simulation |
7016 | AutoCAD P & ID |
7022 | Autodesk Utility Design |
7023 | Autodesk Topobase Client |
2008 Product ID |
6000 | AutoCAD Civil 3D |
6001 | AutoCAD (Registry Cookies: ACAD-6001; ARD-6001) |
600A | AutoCAD OEM (Registry Cookie: AOEM-6001) |
6002 | Map |
6003 | Inventor Series |
6004 | AutoCAD Architecture (former Architectural Desktop) |
6005 | AutoCAD Mechanical |
6006 | AutoCAD MEP (former Building Systems) |
6007 | AutoCAD Electrical |
6008 | Land Desktop |
6009 | AutoCAD LT (Registry Cookie: ACLT-6001) |
6012 | ADT for Raster Design |
6013 | Inventor Professional |
6014 | Inventor Professional for Routed Systems |
6015 | Inventor Professional for Simulation |
6016 | AutoCAD P & ID |
6022 | Autodesk Utility Design |
6023 | Autodesk Topobase Client |
2007 Product ID |
5000 | Autodesk Civil 3D |
5001 | AutoCAD (Registry Cookies: ACAD-5001; ARD-5001) |
500A | AutoCAD OEM (Registry Cookie: AOEM-5001) |
5002 | Map |
5003 | Inventor Series |
5004 | Architectural Desktop |
5005 | AutoCAD Mechanical |
5006 | Building Systems |
5016 | Building Systems 2007.1 |
5007 | AutoCAD Electrical |
5008 | Land Desktop |
5009 | AutoCAD LT (Registry Cookie: ACLT-5001) |
5012 | ADT for Raster Design |
5013 | Inventor Professional |
5014 | Inventor Professional for Routed Systems |
5015 | Inventor Professional for Simulation |
5016 | AutoCAD P & ID |
5022 | Autodesk Utility Design |
5023 | Autodesk Topobase Client |
2006 Product ID |
4000 | Autodesk Civil 3D |
4001 | AutoCAD (Registry Cookies: ACAD-4001; ARD-4001) |
400A | AutoCAD OEM (Registry Cookie: AOEM-4001) |
4002 | Map |
4003 | Mechanical Desktop for AIS |
4013 | Mechanical Desktop for AIP |
4004 | Architectural Desktop |
4005 | AutoCAD Mechanical |
4006 | Building Systems |
4007 | AutoCAD Electrical |
4008 | Land Desktop |
4009 | AutoCAD LT (Registry Cookie: ACLT-4001) |
4012 | ADT for Raster Design |
4022 | Autodesk Utility Design |
2005 Product ID |
300 | Autodesk Civil 3D |
301 | AutoCAD (Registry Cookies: ACAD-301; ARD-301) |
30A | AutoCAD OEM (Registry Cookie: AOEM-301) |
302 | Map |
303 | Mechanical Desktop for AIS |
313 | Mechanical Desktop for AIP |
304 | Architectural Desktop |
305 | AutoCAD Mechanical |
306 | Building Systems |
307 | AutoCAD Electrical |
308 | Land Desktop |
309 | AutoCAD LT (Registry Cookie: ACLT-301) |
3012 | Architectural Desktop + Raster Design |
3012 | Autodesk Utility Design |
2004 Service Pack Product ID |
200 | Autodesk Civil 3D |
223 | Mechanical Desktop 2004 DX for AIP |
233 | Mechanical Desktop 2004 DX for AIS |
215 | AutoCAD Mechanical 2004 DX |
207 | AutoCAD Electrical |
2004 Product ID |
201 | AutoCAD (Registry Cookie: ACAD-201; ACLT-201; AOEM-201; ARD-201) |
20A | AutoCAD OEM |
202 | Map |
203 | Mechanical Desktop for AIS |
213 | Mechanical Desktop for AIP |
204 | Architectural Desktop |
205 | AutoCAD Mechanical |
206 | Building Systems |
208 | Land Desktop |
209 | AutoCAD LT |
211 | AutoCAD 2004 Extension 1 - Express Tools |
221 | AutoCAD 2004 Extension 2 - Migration Tools: BDC |
231 | AutoCAD 2004 Extension 3 - Migration Tools: Customization Conversion |
241 | AutoCAD 2004 Extension 4 – Tool Palettes Extension |
111 | AutoCAD 2004 CAD Manager Tools |
2002 Product ID |
101 | AutoCAD |
10A | AutoCAD OEM |
102 | Map |
103 | Mechanical Desktop |
104 | Architectural Desktop |
105 | AutoCAD Mechanical |
108 | Land Desktop |
109 | AutoCAD LT |
111 | AutoCAD Extension 1 - CAD Manager Tools |
121 | AutoCAD Extension 2 |
131 | AutoCAD Extension 3 |
141 | AutoCAD Extension 4 |
2000i Product ID |
001 | AutoCAD |
065 | AutoCAD LT |
002 | Map |
003 | Mechanical Desktop |
051 | AutoCAD Extension 1 - Standards Extension |
052 | AutoCAD Extension 2 - XML Extension |
053 | AutoCAD Extension 3 |
054 | AutoCAD Extension 4 |
Structure of LocaleID (languages)
The language code LocaleID is a 4-character hexadecimal representation of system locale (language, localizatio) of the given product.
LocaleID | Lang.abbr. | Jazyk |
409 | ENU | English |
407 | DEU | German |
040C | FRA | French |
410 | ITA | Italian |
040A | ESP | Spanish |
415 | PLK | Polish |
040E | HUN | Hungarian |
405 | CSY | Czech |
419 | RUS | Rusian |
416 | PTB | Brazilian Portuguese |
804 | CHS | Simplified Chinese |
404 | CHT | Traditional Chinese |
412 | KOR | Korean |
411 | JPN | Japanese |
