CAD tip CAD tip # 8468:
Question
If you want to display - similarly to AutoCAD - a full document path (subfolders) in the Inventor window titlebar, you can use a simple iLogic macro.
Use iLogic to define a new rule (name it e.g. "LongCap") containing a single line:
ThisApplication.Caption = ThisDoc.Path
Then let the rule "LongCap" run/invoke (see Event triggers) automatically on each event of the type "Document open".
Inventor2012
14.2.2012   15541×
this tip shared by ARKANCE experts applies to: Inventor 2012 ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 14826:AutoCAD runs slower on a laptop docked in a docking station.
Tip 14374:The operation is canceled - when checking-in an Inventor assembly into Vault.
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Tip 11376:Attaching a xref to AutoCAD DWG sets a relative path automatically, can I change it to absolute?
Back    All CAD Tips
Categ:
