CAD tip CAD tip # 8473:
Question
AutoCAD layouts are sorted alphabetically when printing or publishing. But alpha sorting does not sort properly sequentially numbered layouts - see the status in the dialog of the LOman utility:
Alphabetically
With the freeware LISP utility CADstudio LOman you can sort your layouts also numerically so that printing will give a proper, logical order:
Numerically, Tabsort
You can download the LOman application from DL Download and load it with APPLOAD.
The LOMAN command invokes the dialog, the -LOMAN command starts the commandline version of this function.
ACAD
15.2.2012   20467×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 6910:An alternative way of switching layouts.
Back    All CAD Tips
Categ:
