CAD tip # 13038:
applies to: AutoCAD · |
Tip 12129: | Atypical use of meshing for tiling a closed shape. |
Tip 9711: | 3DConstruct - converting a 3D mesh to a frame construct |
Tip 8903: | Draw normals of 3DFaces in AutoCAD DWG. |
Tip 8509: | Unfold any 3D mesh into 2D planar form. |
Tip 7216: | How to use 3DFACEs as a definition for terrain surface? (explode 3DFACE) |
iLogic - display information about complexity of an Inventor part. « | » How to prepare a 3D model for manufacturing by removing detailed elements?
