CAD tip CAD tip # 6804:
Question
If you want to explode linetypes (simple dashed, dash-dot, or complex linetypes with shapes) in your AutoCAD drawing to individual simple lines (line segments), you can use a modified version of the TxtExp Express Tool.
Exploding linetypes is similar to exploding texts (SHX fonts). So we have modified the standard TxtExp.lsp tool from AutoCAD Express Tools to work on any object and made a LinExp.lsp tool from it.
Download the LinExp tool from DL Download, load it with APPLOAD and start the LINEXP command. Select the lines you want to convert to the individual strokes and confirm. The resulting geometry is no longer a single line (and may be less precise) - so make sure you work on a copy of your original drawing.
LINEXP breaks up linear entities into separate short entities and gaps (and possibly exploded symbols if you have used complex linetypes).
Note by Thomas M.:
Another solution is to create a PDF and then use the PDF import command to bring back the drawing and scale it back to correct dimensions.
ACAD
20.7.2009   55508×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14709:How to export Fusion drawings to AutoCAD (DWG)?
Tip 14697:How to switch a DWG drawing between CTB and STB plot styles?
Tip 14665:Display complex linetypes on 3D curves in plain AutoCAD.
Back    All CAD Tips
Categ:
