CAD tip CAD tip # 10702:
Question
By default, a DWG file displays only the information about the user/author name and the originating group of AutoCAD versions sharing a common DWG file format (more info).
By automatic storing of additional information (see PreSave below) you can subsequently display the exact AutoCAD version used to save the drawing file.
With newer DWG file versions saved from AutoCAD (any vertical version, including LT), but not from Inventor or Revit, you can find out detailed information about the AutoCAD version and language (flavour, language localization, build number - resp. the service pack), which was used to save the drawing, even without previously storing auxiliar data to custom properties.
For this, you can use the .NET application DWGintVer available on our Helpdesk server - see DL Download and on Autodesk Apps. Run the command DWGINTVER from the ribbon. This tool displays an information dialog with data about the authoring product - use it of course before you save the DWG on your own AutoCAD.
Examples:
By switching the CMDDIA variable you can direct the command output to the command line.
You can also use the DWGintVerCon Windows console application (.EXE) to perform batch report with similar results:
More information on DWGintVer
Alternative method - PreSave
Similar data - AutoCAD version, flavour, language and build of the authoring product for the particular DWG - can be also obtained by setting a custom property. The custom property "LastACADver" can be automatically filled in by the PreSave utility/reactor - see the Tip 7169.
ACAD2022ACAD2018ACAD2016ACAD2014ADTPlantCivil
20.1.2016   26451×
this tip shared by ARKANCE experts applies to: AutoCAD 2022 · AutoCAD 2018 · AutoCAD 2016 · AutoCAD 2014 · ADT · Plant · Civil ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 15038:Texts exported from AutoCAD to PDF appear slightly smaller and misaligned.
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Back    All CAD Tips
Categ:
