New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip # 10693:
Question
With the freeware utility CADstudio NBlockList you can generate a report of all or all selected blocks used (inserted, referenced) in the current AutoCAD DWG file. This list contains also names of any nested blocks (block in a block) of any nesting depth. With each insert block, the function lists the total number of its references and the list of layers it is inserted into.
Example - the Workstation block contains embedded blocks Keyboard and Monitor:
Optionally, this add-on can also export the block list to a CSV file for Excel.
ACAD
14.1.2016
17972×
applies to: AutoCAD ·
