CAD tip CAD tip # 8209:
Question
The installation program of the graphics acceleration driver "nVidia Performance Driver" supports only English versions of plain AutoCAD. But using the following procedure you can install it even on e.g. Czech version of AutoCAD Architecture.
You can trick the setup by impersonating the plain English AutoCAD version, installing the driver and immediately returning the impersonalization back to the original. Please perform the registry changes carefully and with AutoCAD not running.
The signature of the AutoCAD application (any version) can be found in the Registry (example of Architecture 2011):
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.1\ACAD-9004:405
Rename this key (using RegEdit.exe) to ACAD-9001:409. (for version 2010 rename the original key "R18.0\ACAD-8004:405".) Now run the nVidia driver installation - it should complete without errors. Immediately after this installation rename the registry key to its original value! Only the run your AutoCAD Architecture (or other vertical) and choose the new driver.
ACADADTACADMCivilMapACADE
14.9.2011   17323×
this tip shared by ARKANCE experts applies to: ACAD · ADT · ACADM · Civil · Map · ACADE ·
Tip 14896:When starting up, Fusion gets stuck on "Loading additional modules."
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13379:Revit failing on machines with multiple graphics cards.
Tip 12103:Random lines are displayed over my AutoCAD drawing.
Tip 11460:Mental Ray and Arnold is missing from my 3ds Max 2018.
Back    All CAD Tips
Categ:
